I am using the Direct method for convergence of a recycle tear stream. This method has an upper limit to the "Maximum Flowsheet Iterations". I need to run ~270,000 flowsheet iterations, but this method only allows 9,999 at the most. Does anyone know how to change the upper limit on this convergence parameter? I must use the Direct method. The option is located in Simulations|Convergence|Options|Methods|Direct.
Aspen Plus Convergence Method Iteration Limit
Started by Tschannen14, Mar 26 2015 12:28 PM
aspen aspen plus convergence direct method iteration limit flowsheet limit
No replies to this topic
Posted 26 March 2015 - 12:28 PM
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
Detection Limit Of Protein SwabsStarted by Guest_Hartwa_* , 12 Feb 2025 |
