How do we calculate Yield for Gas Plants?
We calculate % C3 product recovery as
(C3 in feed - C3 at De-ethanizer bottom)/C3 in feed x 100
PKS
Posted 01 April 2015 - 12:36 PM
PKS
Posted 01 April 2015 - 12:42 PM
What are you referring to when saying "yield"?
C3 recovery for De-C2 column is calculated like you wrote.
Posted 01 April 2015 - 12:49 PM
Thanks for your reply Zauberberg!!
I am talking about NGL component yields. How are they calculated? Yields in chemical reaction is fine, but here I need clarity on yield of NGL components like propane in Gas Plants.
PKS
Posted 01 April 2015 - 12:53 PM
You are correct, the "yield" terminology is not very appropriate. For physical processes "recovery" is much better definition.
NGL components in your case seem to be C3+. For calculating recoveries, you need to divide C3+ in the NGL product from De-ethanizer bottoms, with C3+ content in the feed stream, and multiply the number by 100.
Posted 01 April 2015 - 01:55 PM
Same is my question? Someone asked me to calculate, I am confused how to calculate or is this really exists? I need help!
Posted 01 April 2015 - 02:10 PM
A good engineer will ask for clarifications from his supervisor, in case he did not understand what is the task about. This will save everybody's time and efforts. Why don't you simply go back to your superior and ask him what did he mean precisely with regards to the NGL yield? Then come back to us for any further clarifications needed.
Posted 01 April 2015 - 02:16 PM
Same is my opinion. I just completed my homework.
Going back and asking before confirming myself was not fair. ![]()
Thanks!!
PKS
Edited by PKS, 01 April 2015 - 02:22 PM.
Posted 08 April 2015 - 02:22 PM
Zauberberg!!
I got the answer to my question. In Gas Plants the yield is calculated as Amount of product per MMSCF of feed gas. e.g. C3 yield is the C3 recovered per MMSCF of feed gas.
Thanks!
PKS
Ethylene PlantsStarted by Guest_panoska_* , 08 Oct 2024 |
Effect Of Present Of Methanol In Ethane Feed To Olefin PlantsStarted by Guest_h.eghbali_* , 28 Nov 2021 |
Designing Pilot Plants, Factors While Experiment DesignStarted by Guest_ChinmoyBasak_* , 12 Aug 2020 |
Hydrotest Pressure For Piping B31.3 - Significance Of Yield StrengthStarted by Guest_rs20170808@gmail.com_* , 12 Oct 2019 |
Corrosion Inhibitors Options In Teg Dehydration PlantsStarted by Guest_shurimano_* , 07 May 2018 |
