Hello all! I am a student working on a simulation of a dehydrogenation column of propane to get propene.
I'm using Aspen V8.4 we get the next error when we ran the column.
Posted 08 April 2015 - 08:50 AM
Posted 08 April 2015 - 09:17 AM
Well, you must first convert propane to propylene in a reactor.
Posted 08 April 2015 - 09:45 AM
Our feed data it's provided by the company that designed the project, so we're not supposed to deal with the reaction. We are just supposed to simulate the separation and once simulation is successful then add a new feed stream and optymize it's feed stage.
Posted 08 April 2015 - 11:27 AM
Every stage must have vapor and liquid. Do you have condenser at the top and reboiler at the bottom? Errors like "tray drying up" often indicate that the specifications are impossible to meet. Change your specs so that you will get convergence. If you cannot figure out where your specs are impossible, choose something simple like a bottoms flow rate and reflux ratio. Once you get convergence, then review results and modify your specs gradually till you understand how the model behaves. Save your work often as a new file name so that you can revert to an older working model if you fall into a pit.
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
