I would like to know the best practices for the preparation of internal surfaces of oil refinery equipment (vessel/tower/reactor shells) for visual inspection?
currently we use HP washing (10,000 psi) but the inspection dept always complain and demand 2nd or 3rd attempts which results in significant delays.
We have also tried grit blasting (SSPC-SP6 and even SP10) but it is also a lengthy process (including clean up of spent grit) and dust generation is always an issue.
Thanks.
Oil Refinery Vessel Internal Surface Preparation For Inspection Best P
Started by syxxty6, Apr 09 2015 02:35 PM
refinery oil surface preparation inspection
No replies to this topic
Posted 09 April 2015 - 02:35 PM
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
Pumpback Reflux/ Internal RefluxStarted by Guest_Venkat @89_* , 26 Sep 2024 |
Ways To Reduce Wetted Surface Area In Psv SizingStarted by Guest_KoreaGyu_* , 21 Aug 2024 |
