Dear all in case of reverse flow through diverse check valves API 521 section 4.3.4.4 says that:
"Where no specific experience or company guidelines exist, one may estimate the reverse flow through series
check valves as the flow through a single orifice with a diameter equal to one-tenth of the largest check valveās nominal flow diameter"
I have a water injection pump (2 working 1 standby) with following details:
Suct pr : 7 barG
suct design pr : 17.5 barG
discharge pressure: 275 barG.
normal flow : 700 m3/hr.
discharge line : 16 inch,
The discharge lines connect to a header connecting all these pumps....discharge line of each pump has a set of diverse check valves to avoid incidence of high pressure to the suction side.
Now in case of that these check valves fail what do you recommend:
- 1% of the normal volumetric flow( 1/10 of dia will give 1% area only) through the discharge line as per API as the PSV design Load.
- If not then what are the equations which I shall use to calculate the reverse flow through the assumed RO of 1.6" (16"/10) in these high differential pressure conditions, I want to develop an excel tool for this case.
I have read several forums where people are suggesting for 10% vol flow to be taken for PSV load calc but I did not find any basis for that so thought of writing to cheresource....
Please give your opinion.
B.R.
Pramukh
Edited by pramukh, 12 April 2015 - 05:56 AM.
