Dear:
Please share with me your idea about water washing of caustic line after construction.
Best regards
M.R.Rahimzadeh
Posted 18 April 2015 - 10:04 PM
Dear:
Best regards
M.R.Rahimzadeh
Posted 19 April 2015 - 02:51 AM
If you are referring to line flushing prior to commissioning, achieving water velocities between 1.5 and 2.0 m/sec will generally remove all dust and debris from the line. Caustic lines are normally of small diameter (<2") so you may achieve the same by purging the lines with steam or Nitrogen.
Posted 19 April 2015 - 09:03 AM
It is standard practice to wash new pipe and fittings with a safe fluid (water) after construction. It is usually synergistic with pressure testing too.
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
Inlet Line Not Free DrainingStarted by Guest_Asifdcet_* , 07 Apr 2025 |
