Hi there!
I am trying to get a program working for a class project in Aspen. I manually drew in my starch molecule and used the calculate bonds option to get all of the properties for the molecule but then when I go to run my simulation I keep getting this error:
VAPOR PRESSURE MODEL PL0XANT HAS MISSING PARAMETERS:
PLXANT/1ST ELEMENT (DATA SET 1) MISSING FOR COMPONENT STARCH
****PROPERTY PARAMETER ERROR
ERRORS ENCOUNTERED IN CALCULATION OF VAPOR-LIQUID K-VALUES USING
OPTION SET IDEAL FOR KVL.
And then it stops calculating. How do I fix this????
Thank you!
