What will be the difference on the performance if we will install a chemical injection quill on horizontal Pipe or vertical pipe?
Injection Quill Orientation
Started by JP2078, May 07 2015 06:51 AM
Posted 07 May 2015 - 06:51 AM
Posted 07 May 2015 - 08:55 AM
JP2078,
As far as i know, an injection quill is installed in horizontal piping; but there would be no difference on its performance if it is installed in horizontal or vertical piping. Orientation of 45 degree angled end is important in injection quill performance which should be face downstream for liquid stream and face upstream for vapor stream...
Need Help To Determine Axis Orientation Of Lithium NiobateStarted by Guest_Petek_* , 09 Feb 2025 |
![]() Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
![]() Chemical Injection PointStarted by Guest_Lyne_* , 15 May 2024 |
Water Injection SystemStarted by Guest_Frederick34_* , 08 Jan 2024 |
