Posted 08 January 2024 - 01:44 PM
Posted 09 January 2024 - 06:49 AM
I have noticed that several distillation columns that have water injection systems at the top for washing, operate at temperatures of 120-125 °C (248-257 °F) and pressures that can be 0.5-1 kg/cm2g (7-14 psig).
I have never seen distillation columns that have water injection systems at the top for washing.
Or do you mean water injection into the overhead line upstream the condenser?
What kind of distillation columns are you talking about? What service?
Edited by PingPong, 09 January 2024 - 06:54 AM.
Posted 09 January 2024 - 07:08 AM
I have noticed that several distillation columns that have water injection systems at the top for washing, operate at temperatures of 120-125 °C (248-257 °F) and pressures that can be 0.5-1 kg/cm2g (7-14 psig).I have never seen distillation columns that have water injection systems at the top for washing.
Posted 09 January 2024 - 07:30 AM
Injected water that vaporizes lowers the temperature of the overhead vapor.
You have to inject so much water that there will be free water left at the inlet of the condenser.
In your simulation you must use an adiabatic flash for that, not simply fixing the temperature at that of the column top.
Water Hammer In CondenserStarted by Guest_Ahmadhamzahperta_* , 31 Oct 2025 |
Simulation Of Natural Gas Water Dew PointStarted by Guest_guoyinyanliner_* , 03 Nov 2025 |
Foam System Criteria For Hc Condensate Storage TanksStarted by Guest_Haideri_* , 28 Oct 2025 |
Pem Water ElectrolysisStarted by Guest_tomr91_* , 29 Jul 2025 |
