Hi guys ! what is the best method to save the PFD as a PDF file in HYSYS v8.6 !! i tried to take scree shot but when i print it on A3 format paper streams are not very clear !
Help ! thanks.
Posted 22 May 2015 - 06:50 AM
Help ! thanks.
Posted 23 May 2015 - 12:57 AM
You can use "print" option from the file menu and then choose PDF creator from the printer list. Of you don't have Acrobat Pro, there is a plenty of free PDF creators you can download from the web.
http://www.pdfforge.org/pdfcreator
http://www.foxitsoft.../PDF-create.php
Posted 23 May 2015 - 05:28 AM
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
