How To check the PH of crude oil and refinery products? Normally the PH of inorganic substance have been checked.Is there Any method to check the PH pf hydrocarbons?
Posted 01 June 2015 - 01:33 PM
Posted 01 June 2015 - 02:36 PM
pH applies to aqueous solutions only, because it is a measure of concentration of H+ ions. It has no meaning for Hydrocarbons.
Posted 01 June 2015 - 02:47 PM
Thanks.
Posted 01 June 2015 - 11:16 PM
One way of checking pH of light petroleum products is by extracting the product with an equal quantity of 7.0 pH water and checking the pH of the water extract.
pH of crude oils can also be checked in the above way if the crude oil is light and water separates from it on settling. For heavy and viscous crudes a pH meter may be useful. For heavy crudes, dilute with an equal quantity of neutral solvent like iso octane and use pH meter. Dilution factor may be stated while reporting the result.
This was how we were doing in the good olden days.
Posted 04 June 2015 - 10:34 AM
How To Have 2 Property Method In Aspen Plus Based On Phase?Started by Guest_m.ghaziasgar_* , 21 Aug 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Vertical Separators Best MethodStarted by Guest_fmalik_* , 02 Dec 2023 |
