Spray Dryer
#1 shamir
shamir
  • 25 posts
Posted 13 June 2015 - 01:00 AM
HI All
     I want to calculate  mass flow rate of hot air , energy requirment  of evaporation rate of water in  spray dryer,
Type of spray dryer: co-current spray dryer.
Heating media : hot air .
Inlet temp of air : 130 0c
Outlet temp of air : 60 0c
Inlet moisture content= 40 %
outlet moistrue content =1.5%
specific heat of material = 0.7 kj/kgk
  • 6,800 posts
Posted 13 June 2015 - 01:58 AM
Shamir ,
Unless you have way to measure the air flow rate or air velocity , there is no way to get access to the mass flow rate of air with the data submitted .
You may be able to perform a mass and heat balance on the product side which could help you to determine the air flow .
Edited by breizh, 13 June 2015 - 02:05 AM.
#3 shamir
shamir
  • 25 posts
Posted 13 June 2015 - 03:46 AM
Attached File  heat load requirments.xlsx   10.51KB   46 downloadsThanks for guidance,
i have calculated mass and energy balance of spray dryer with assumption of 30% losses in dryer . But i am not confident  about the load that i have calculated. i have also attached energy balance calculations so please guide further for the same.
In addition to that what are the consideration for heat load calculations.
#4 breizh
  • 6,800 posts
Posted 13 June 2015 - 05:17 AM
http://www.nzifst.or...ions/drying.htm
Shamir ,
I've added a link to support your work . You should review the basic about energy balances and drying process.
Enjoy
