Dear cheresources members,
I have a question with regards to water quality for the hydraulic-liquid seal upstream flare system if there is any requirement for water quality to be used in the drum
Rgds
Posted 15 June 2015 - 09:45 AM
Rgds
Posted 15 June 2015 - 10:32 AM
1) Non-corrosive to the vessel and instrument components;
2) Does not contain species incompatible with flare gas, that can cause e.g. creation and deposition of solids;
3) Readily available on site.
Posted 16 June 2015 - 02:28 AM
fedi abdeljawed,
The water used in seal drum should be compatible with drum material and if the minimum ambient temperature is subzero, must be protected against freezing, say, by adding anti freezing agent such as Ethylene Glycol...
Pem Water ElectrolysisStarted by Guest_tomr91_* , 29 Jul 2025 |
Isenthalpic Throttling With Flashing LiquidStarted by Guest_lofarcio_* , 06 May 2022 |
