Agitator Power Consumption Calculation
#1 Chirag Prajapati
Chirag Prajapati
  • 6 posts
Posted 17 July 2015 - 05:33 AM
I wanted to calculate power consumption of agitator having 3 impellers installed on a single shaft and running at same speed. All impellers attached to shaft is identical.
On internet I found articles for power consumption calculation for agitator with one impeller only.
How to calculate power consumption for agitator having multiple impeller on single shaft.
#2 latexman
  • 1,815 posts
Posted 17 July 2015 - 07:09 AM
3 x (power consumption for agitator with one impeller only) is the simple answer, especially if the spacing between impellers is close to the diameter of the impeller blade(s).  There are corrections in the literature for spacing, but those details are usually handled by the agitator fabricator who has much more data than is in the literature.
#3 Chirag Prajapati
Chirag Prajapati
  • 6 posts
Posted 17 July 2015 - 08:08 AM
Latexman thanks for reply
will above formula will remain same if different type impellers are attached on same shaft and rotating at same speed.
#4 latexman
  • 1,815 posts
Posted 17 July 2015 - 08:33 AM
If different type or size impellers on one shaft, then you sum the individual power consumptions of each type.
#5 breizh
  • 6,724 posts
Posted 17 July 2015 - 09:03 PM   Best Answer
You may find good info reading these  documents .
Hope this helps
Edited by breizh, 19 July 2015 - 07:43 PM.
