hi every one
i have simulate a crude oil in HYSYS but in result i have 1.0 for vapour/phase fraction, that in reality not true, what is the mistake that i do to have this resultsmust be
Posted 21 July 2015 - 05:29 PM
hi every one
Posted 22 July 2015 - 01:01 AM
if you know that at those conditions a liquid phase must exist possibly the wrong result is the result of uncorrect characterization procedure,
you can repeat the procedure and examine the list of generated *pseudo* components,
you may simply test the results solving a series of flash operations (vaporization..) which is my preferred way to test with Prode.
Characterization procedures are simply but may require some care to select the correct values to enter.
you may also compare values, the different simulators may introduce little variants but given similar inputs and correlations the properties for generated pesudo components shouldn't be too different...
Posted 22 July 2015 - 01:26 AM
Hello titim,
I used the data provided by you to generate the crude in Unisim and I obtained Vapour / Phase Fraction = 0.876.
Posted 22 July 2015 - 04:28 AM
You only have the TBP curve up to 74.4 wt%, so Hysys extrapolates in some way, that is obviously too optimistic.
It is an illusion to think that Hysys knows what you don't know.
Without more TBP data you can not accurately simulate anything.
Is this crude Hassi Messaoud 46 oAPI ? I don't have a crude assay of that, but I do know that it contains some 0.2 % asphaltenes, so its TBP endpoint will be above 800 oC. What the shape of the TBP curve between 380 and 800 oC is is anybody's guess. Best is to look at similar API crudes.
Posted 26 July 2015 - 02:16 AM
hi, yes crude of HASSI MESSAOUD
Posted 26 July 2015 - 07:48 AM
You need to obtain a Crude Assay or SimDis (such as ASTM D2887) of that crude if you want to do any accurate simulations. You should make that clear to the person who asked you to do this work.
Is that 662 oF at 36.26 psia supposed to be the outlet conditions of the crude charge heater in a CDU ?
If so, is that an existing CDU or a new one?
Posted 27 July 2015 - 02:16 AM
hi
yes that from an existing CDU (2.2 bars and 350 °C
Posted 27 July 2015 - 03:21 AM
Note that the 36.26 psia that you used corresponds to 2.5 bara, not 2.2 bara.
In an existing CDU you could try to use the actual quantities of all products, in combination with their composition (of gas and LPG products) and ASTM distillation (D86 for gasoil and lighter, D1160 for atm, residue), to reconstruct the crude feed.
Three Phase Seperator ModificationStarted by Guest_halkeshhulk_* , 10 Jun 2025 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
![]() Psv Flashing, Sizing Outlet Line 2-Phase.Started by Guest_felderosfelder101021_* , 09 Dec 2024 |
C Factor For Erosional Velocity For Multi-Phase Flow (Nat Gas/ ProduceStarted by Guest_Sam11_* , 10 Sep 2024 |
