I know both of they simplified the acid gas removal but what is the differences between them? Like what are the differences between the process of the AGR.
Edited by nuel92, 27 July 2015 - 09:21 PM.
Posted 27 July 2015 - 08:32 PM
Posted 28 July 2015 - 05:45 AM
Sulfinol X and Sulfinol M are both Shell processes that combine physical and chemical solvents. Both will have a Sulfolane base. The letter on the end indicates the chemical solvent it is mixed with. M means the chemical solvent is MDEA. X means it is MDEA and Piperazine. D means it is DIPA. Sulfinol is used mostly in gas plants that have a high amount of Mercaptans, COS and H2S. It reduces the number of processes needed to achieve a clean gas.
What Are The Differences Between Ph,orp & Chlorine Dioxide AnalyseStarted by Guest_Radha Krishnan Siva Kumar_* , 01 Apr 2024 |
Differences Between Demineralized Water And Boiler Feed WaterStarted by Guest_Vegeta_* , 09 Aug 2022 |
Similarities And Differences Of Liquids And PowdersStarted by Guest_SamerIssa_* , 06 Jan 2019 |
Differences Between These 2 FoamsStarted by Guest_Jason73_* , 01 Aug 2018 |
Answered
Differences Between Density At 15 C (In Air) And Density At 15 C (In VStarted by Guest_Tolinorton_* , 13 Aug 2014 |
