Hello everyone,
Has anybody managed to size a liquid - liquid column in hysys / pro/II?
Can anyone recommend some books or articles on how to size a liquid - liquid column ?
Thank you.
Posted 28 July 2015 - 02:16 AM
Hello everyone,
Thank you.
Posted 28 July 2015 - 10:17 AM
See Treybal.
Posted 28 July 2015 - 11:40 PM Best Answer
Hello everyone,
Thank you.
You can see Mass Transfer by Treybal where the liquid liquid extraction column. There is less literature available in open domain; it's very difficult to estimate the interfacial tension which itself is a critical parameter. There are two aspects to it, one is process design which probably commercial simulators may help (need proper thermo to take care of estimates) and once the loads are available, then the design of hardware i.e. an extraction column which is typically a sieve tray column. You can discuss with tray vendors if they can share some guidelines (seriously doubtful) or at least an approach to it.
Few things which you should consider while designing hardware would be,
1. Liquid flux (m3/h-m2) to ensure emulsion bands underneath of each tray and at top of tower is within limits
2. droplet diameter to see entrainment and should be assessed in conjunction with hole velocity
3. Residence time of settling & rising of phases
hope it helps.
Posted 30 July 2015 - 02:06 AM
Thank you all very much for your answers.
Cheers.
Posted 30 July 2015 - 11:45 AM
But be careful using Treybal. You don't need downcomer restriction as he says.
Posted 03 August 2015 - 01:36 AM
Thank you Bobby
Posted 01 September 2015 - 01:10 PM
You can also look for the tutorials provided by hysys/Pro-II/Petrosim
Yogesh
Steam Drum SizingStarted by Guest_nastaran_* , 01 Dec 2025 |
Sizing Of Condensate Return VesselsStarted by Guest_panoska_* , 23 Oct 2025 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
Sizing And And Process Control Of Filter PressStarted by Guest_Amalina Jamil_* , 11 Mar 2019 |
Nozzle Sizing CalculationStarted by Guest_BabRafiq1_* , 26 Aug 2022 |
