Reciprocating Compressor Piston Rod Lubrication
Posted 09 August 2015 - 11:27 AM
Posted 09 August 2015 - 06:41 PM
Kirang:
There is nothing difficult about lubricating a reciprocating piston rod or piston rings. This is (or should be) explained in your compressor's operating and maintenance manual. You should read it diligently and carefully. In case you were never given or received the specific manual - or you lost your copy - you can read and study the material I am attaching below.
The lubrication system explained in the documents is fairly routine and is used to lubricate compressors delivering up to 10,000 psig of discharge pressure. 2.5 kg/cm2 (36 psig) is a drop in a bucket and nothing to be concerned about.
CPI Lubrication Equipment for Compressors.pdf 6.08MB
36 downloads
Lubricating Reciprocating Compressor Cylinders & Piston Rods.docx 229.06KB
35 downloads
Centrifugal Compressor TroubleshootingStarted by Guest_sggifrance@gmail.com_* , 14 Sep 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
![]() ![]() Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
![]() Centrifugal Compressor RecycleStarted by Guest_Lyne_* , 19 Aug 2025 |
