Hi All
We have found what we believe to be ammonia converter catalyst in equipment downstream of our ammonia converter. This was discovered after we removed the flow control valve on a high pressure direct line to the associated urea plant. This particular flow control valve was operating very erratically and was not passing the usual amount of flow. We are currently awaiting results of lab analysis to confirm it is catalyst, but visual observation leads us to believe it is.
Can anyone share their experiences with a similar situation, where catalyst particles are passing from a reactor vessel and travelling through pipework, exchangers and valves entrained in a liquid flow.
How do we quantify the risk associated with potential erosion of the pipework, thermowells, heat exchanger tubes etc?
What approach has other people taken when this situation has been observed? Shutdown or keep running after accepting and understanding the risk to plant?
So far, we have not noticed any changes in operation of the ammonia converter. Pressure drop is the same, NH3 conversion is the same and temperature profile is the same.
The catalyst itself is 1.5mm-3mm irregular iron based particles.
We are working with the converter OEM along with the catalyst supplier. However, it would still be helpful to gain some insight from other people in the industry.
I can provide more specific information if required, but general comments, what approach other plants have taken and what similar situations have been seen are what I would like to hear about if possible.
Sam
