I am working on closed drain system of a gas processing plant.
We have a closed drain system having a below grade closed drain vessel.
Drain lines connected to process equipment is either 2" or 3" and are for maintenance drain. These are above ground drain lines. Underground part of same drain line is indicated as 4". Slope is 1:100 for these lines.
Main underground drain header is provided with a slope of 1:400 and this is connected to closed drain drum.
We are calculating drain volume for each equipment with margin. Now the highest drain volume is considered for closed drain drum size.
Please advise on the followings:
1. Basis for closed drain drum sizing is correct or not.
2. How to determine draining rate for each equipment ?
3. How to verify process drain size 2" or 3" is correct or not ? Is it necessary to design for self venting for maintenance drain lines?
4. Do we need to perform underground header size for the maximum draining rate ? What % of liquid filing needs to be considered ? Is there any issue if main ug header has higher capacity than individual process drain lines?
5. Is it okay to have different slope for individual drain line (1:100) and main header(1:400) ?
6.If a process equipment is drained via level control into a closed drain header, will self venting criteria to be used for these process drain line sizing ?
Thanks.
