Kindly suggest what will be discharge head of the pump for pump manufacturer, according to the attached drawing.
Regards.
Edited by NBD3000, 20 August 2015 - 04:39 AM.
Posted 20 August 2015 - 04:31 AM
Regards.
Posted 20 August 2015 - 04:48 AM
Water level will be maintained according to sump level but to reach the water back to tank require pump.
My question is will the pump require 30m head or 10m head or other???
Posted 20 August 2015 - 04:52 AM
Discharge head will be discharge side elevation from the center line of the pump. In your case it is (5+x+Line loss) m or (10+x) m. x is length of small vertical line above pump.
Posted 21 August 2015 - 01:47 PM
![]() Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
