Ammonia Liquid Pump Lines
7 replies to this topic
#1 trungphu
trungphu
  • 106 posts
Posted 05 September 2015 - 02:00 AM
Dear all,
I have a couple of queries about a liquid ammonia pump that is operating at -33 Celsius degrees.  What are the main purposes of the equalizing pipe to suction vessel and the line for pump quenching?  The suction and discharge pressures of the pump are, respectively, 0.6 barg and 11 barg.
I hope to get valuable answers from professional engineers in the forum.
Edited by trungphu, 10 September 2015 - 04:21 AM.
spelling, grammar
  • 6,797 posts
Posted 05 September 2015 - 02:36 AM
Consider these resource to support your work .
Hope this helps
Good luck!
#3 trungphu
trungphu
  • 106 posts
Posted 10 September 2015 - 04:19 AM
Thank Mr. Breizh for your help
#4 Satyajit
Satyajit
  • 87 posts
Posted 18 September 2015 - 01:09 PM
      Appreciate your questions. These are good points .  I think the lines you  mentioned are  meant for pump cooling and to remove any vapors formed in pump CAN.  Please submit your pump P&ID so that so  I can give you  exact reasons  for the lines provided.
Kind regards,
Satyajit
#5 trungphu
trungphu
  • 106 posts
Posted 04 October 2015 - 10:47 AM
Thank you so much , Mr Satyajit. I  dont know how to upload a photo on this website.
#6 fallah
  • 5,019 posts
Posted 04 October 2015 - 01:30 PM
trungphu,
By clicking on "more reply options" at the bottom of the window in which you write the reply, you can attach and upload any file relevant to that reply...
#7 trungphu
trungphu
  • 106 posts
Posted 07 October 2015 - 11:07 PM
Thank you, Mr. Fallah.
Mr. Satjaity : Please refer to the PI&D I attached  to this reply.
#8 manojkaila
manojkaila
  • 66 posts
Posted 08 October 2015 - 08:47 AM
Dear,
As per my understanding this line is a casing vent.  This is required for introducing cold NH3 liquid into the pump, cooling it down by vaporization of the initial NH3 and allowing the pump to pump the cold, saturated NH3 liquid without vapor binding the pump casing.  The pump can only pump liquid and will vapor bind if filled with vapor.  Once the initial cool-down of the pump is done, the casing vent line should be blocked and closed to allow the pump to operate normally with liquid.
