Boutique Distillery Alcohol Question
#1 distillerdave
distillerdave
Posted 23 September 2015 - 06:46 AM
hi all,
i am working at a boutique distillery and am trying to create a spreadsheet to increase efficiency of production.
We currently measure the distillate from the still with an Alcometer and then need to add filtered water to bring it to a strength of 43% ABV.
Currently we convert the measured reading to a 'calibrated' reading at 20degC and then its a rather rough process of adding water and rechecking until the spirit is at the required ABV.
I basically want to create an excel spreadsheet to enter the measured reading and have it automatically calculate the amount of filtered water to add to the distrillate to bring it to the required ABV.
I am currently trying to get a hold of a copy of the table attached that is compatible to import into excel and create a formula.
Does anyone know of where i can obtain a 'cleaner' copy of these tables in PDF form?
Or does anyone else have any suggestions?
  • 6,939 posts
Posted 23 September 2015 - 06:57 AM
Probably someone like Katmar should help you , he has an extensive knowledge on this matter .
#3 latexman
  • 1,893 posts
Posted 23 September 2015 - 09:56 AM
How do you measure the filtered water for the dilution?  Do you measure mass, mass flow rate, volume, or volumetric flow rate?
#4 Bobby Strain
Posted 23 September 2015 - 11:29 AM
There is lots of information here.
http://homedistiller.../dilute/measure
#5 distillerdave
distillerdave
Posted 25 September 2015 - 05:40 AM
Thanks guys,
We currently only do smaller volumes, So measure the quanty of spirit and its Abv, And then add a volume of water to it to bring it to 43%
#6 breizh
  • 6,939 posts
Posted 28 September 2015 - 01:28 AM
http://www.sugartech...ol/strength.php
Consider this link or Katmar's tool also mentioned in the link .
Should help you .
