3-Way Globe Valve Sizing
valve sizing 3-way valve globe valve
#1 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 01 October 2015 - 12:01 PM
I am currently in technical clarifications regarding a new 3-way globe valve. The valve will have two operating cases:
1- Full flow: Where the fluid flows 100% through the valve without diversion
2- Partial flow: Where 50% of the flow is diverted and the remaining 50% flows through the valve
It's a globe valve
The vendor has submitted their calculations and came back with Cv bigger than the one I calculated using ISA 75.01.01 (2012). I double checked my calculation using our company's software and all is in line with my calculation.
I believe I should accept the vendor's calc. Any thoughts/recommendations?
Sherif
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 01 October 2015 - 01:48 PM
If you just accept it, then why did you do all that verification work? It can happen sometimes that vendors make mistakes. You can ask them how did they perform sizing of this particular valve and offer them your calculations as a support to your doubts.
Double-check your calculations, just to make sure you did it all right.
#3 SPC
SPC
  • 28 posts
Posted 03 October 2015 - 07:34 AM
Hi Please check again Cv for your Valve as follows:
Liquid Flow =            N1*  Cv  *  √  Δ P  /  G Liquid Flow = l/min     N1 = 14.42     Δ P = Pressure Difference, bar   G = Specific Gravity
1st case
1) find out Lquid flow for above case
 2) Find Pressure drop across your valve
a) Pressure at Inlet of Valve = Source Pressure - Pressure loss due to flow /Frictional drop - Pressure drop due to any equipment / Filter / strainer etc.)
B) Pressure at Just Outlet of Valve = Destination Pressure + Pressure loss due to flow /Frictional drop + Pressure drop due to any equipment / Filter / strainer etc.)
Hence, Pressure drop across Valve = Pressure at Inlet of Valve- Pressure at Just Outlet of Valve
   OR
If valve is installed downstream of Pump, you can calculate Pump Head (in bar) at flow for case-1 & consider Average sp. gravity
Do your calculation for 2nd case also.
Hope this helps,
SPC
#4 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 05 October 2015 - 10:29 AM
Thanks everyone for the feedback.
I did the calc again and it still has the same results. I have scheduled a conference call with the vendor to discuss. Will keep you posted :)
