If i understood it correctly, there is a component that can be either positive charged, either neutral acc. the reversible reaction:
C11H21N (liq1) + CO2(g) + H2O(liq2) <--> C11H21NH+(aq) + HCO3-(aq).
The switch from ionic to neutral form of the solvent (i.e. reverse reaction) is endothermal.
I don't know exactly what are the inputs and outputs for the reactor, so i just assume:
*inputs:
- a stream with a known composition (C11H21NH+, H2O), pressure and temperature;
*reactor:
- reactor is operated continously;
- reactor is simulated as a liquid-gas separator with a heat duty;
- reaction reaches equilibrium;
*outputs:
- a gas stream;
- a liquid stream consisting in two liquid phases (water & solvent in neutral form).
It would be helpful, for determination of problem approach, to know what is the purpose of having this reactor simulated in Aspen.
Is it after all necessary to have this block within an Aspen flowsheet? If not, then it would be better to make a reactor model in MATLAB or Excel.
Observation: Aspen Plus and HYSYS don't have the cyclohexyl piperidine in their databank, so it has to be defined via Joback group contribution method, even more there is a real challenge to have the ionic form included in the simulation.
