Hi all,
I am wodering about Joule Thomson coefficient,
In Gas dehydration process using TEG, bottom stream of contactor flow through a valve to decrease the pressure. at that time, i found that the temperature of stream increased.
I think, joule thomson is the factor which makes this situation (Increase in temperature when pressure decrease)
and also, in case of water it has same tendency. (water Joule thomson coeffcient <0 celcius at 250 celcius)
why Joule-thomson has minus sign especially water and TEG ??
Is there any relationship with water chemical structure (hydrogen bonding)?
Thank you for your time in advance.
Soyeon.
