Non Newtonian Fluid
#1 farid.k
farid.k
  • 384 posts
Posted 18 October 2015 - 06:31 AM
Any one has experience to do hydraulic calculation for non newtonion fluid?
The fluid that i referring to is foam for fire water. I dont have idea to choose viscosity value as in the foam datahseet, the viscosity info state that the fluid is non newtonian fluid
  • 6,732 posts
Posted 18 October 2015 - 07:03 AM
hi ,
You should consider to use google and foam eductor , very common device to transfer foam from tank or drums . Generally the pipe length is very short.
#3 farid.k
farid.k
  • 384 posts
Posted 18 October 2015 - 08:39 AM
I did read some typical process standard, for non newtonion hydraulic calculation should be referred to vendor or supplier.
