What is the main criteria/paramter(s) for selection of Strong Acid Cation (SAC) Resin and Strong Base Anion (SBA) Resin for deminerlization? If you have different quotations supplied by the vendor, what will be the paramter?
Kindly assume regenerant provided by all the vednors remains the same.i.e. HCL In my view following are the key paramters that should match with your existing conditions
Ionic Form
Functional Group
Total Exchange Capacity
Operating Temp
Service Flow
Service cycle
Regenerant Conc.
Regeneration Flowrate
Regeneration Time
Kindly also explain the reason behind your answer. Thanks in advance.
