Online Ph Meter In Complex Fertilizer Industry
#1 msaexcel@gmail.com
msaexcel@gmail.com
  • 5 posts
Posted 28 October 2015 - 07:50 AM
hello,
we have online pH meter in our scrubbing section of complex fertilizer plant(DAP Plant). due to scaling & other impurities in phosphoric acid, pH meter shows wrong indication.
whether this problem is faced by everyone?
what are they doing to eliminate this problem?
thanks.
#2 manojkaila
manojkaila
  • 66 posts
Posted 31 October 2015 - 05:49 AM
Dear,
I dont have the same fluid experience but normally for any Such critical PH meter there must be small skid. There must be manual sample point after the PH meter & we need to take sample at any regular interval to cross check the accuracy of reading.
#3 breizh
  • 6,942 posts
Posted 31 October 2015 - 06:01 AM
Probably the vendor of this equipment should advice , definitely regular calibration and probe cleaning is a must . Can you provide a sketch or PID for us to understand better and provide effective support ( pipe diameter , flow rate , location of the probe ,etc) ?
Hope this helps
#4 P.K.Rao
P.K.Rao
  • 265 posts
Posted 01 November 2015 - 11:55 AM
A filter is normally used for removing suspended and undissolved matter which may deposit on the electrodes leading to erroneous results. Please check the filter if there is any. Otherwise, use a filter. The meter (electrodes) has to be cleaned and calibrated with pH buffers periodically
#5 msaexcel@gmail.com
msaexcel@gmail.com
  • 5 posts
Posted 17 December 2015 - 05:39 AM
hello,
thanks for all valuable suggestions.
after installation, i'll try to give feedback.
