Equation Of State Selection For Complex Mixture
simulation
#1 alic4
alic4
  • 3 posts
Posted 02 November 2015 - 09:19 AM
Hello
I want to dry gas mixture by multiple flash drums with most methane recovery, but I want to know which simulator is the best?(Aspen Hysys, Aspen Plus or Pro II) and also which EOS or activity model is more accurate with my composition?
composition:(temp: 25 and pressure 70 barg)
C1 84.3719 C2 5.4499 C3 2.2251 i-C4 0.4875 n-C4 0.7502 i-C5 0.1674 n-C5 0.1355 m-cycl-C5 0.005 n-C6 0.0873 n-C7 0.0327 n-C8 0.0158 p-Xyl 0.0036 Cumen 0.0008 n-C9 0.0059 Benzene 0.003 Cyclo Hex 0.0056 M Cyclo Hex 0.0087 Toluene 0.0018 n-C10 0.0022 C11+ 0.0002 N2 3.482 CO2 2.0584 H2S 0.6894 COS 0.0003 MMCAPT 0.0029 EMCAPT 0.0163 nP-mercaptan 0.0019 nB-mercaptan 0.0003 1-pentanthiol 0.0003 H2o 0.0302
#2 Lucian Gomoescu
Lucian Gomoescu
  • 44 posts
Posted 02 November 2015 - 11:05 AM
You can go for HYSYS with Sour Peng-Robinson fluid package.
#3 serra
serra
  • 311 posts
Posted 05 November 2015 - 09:58 AM
you should be able to solve that problem with all those simulators and others...
basically you need to solve a series of VLE calc's,
not a difficult task with a suitable thermo package,
I have solved similar problems with the extended Peng Robinson model included in Prode Properties,
complex mixing rules can add accuracy but you may be required to fit the model...
#4 alic4
alic4
  • 3 posts
Posted 10 November 2015 - 04:58 PM
thanks for your comment
#5 malcolmbutler
malcolmbutler
  • 4 posts
Posted 25 November 2015 - 11:23 AM
Like the above comment, I would use HYSYS for sure. Good luck!
