Fired Heater Design
Posted 02 December 2015 - 05:29 AM
Posted 02 December 2015 - 07:15 AM
Posted 02 December 2015 - 07:29 AM
Hi Fallah
Thank you for help. but i need a guide or references about furnace design.
Posted 02 December 2015 - 07:59 AM
mhamdi khaled,
Then try using the book:
IHDUSTRIAL and PROCESS FURNACES PRINCIPLES, DESIGN and OPERATION
By: Peter Mullinger, Barrie Jenkins
Posted 02 December 2015 - 08:41 AM
Thanks for help.
Posted 03 December 2015 - 05:40 AM
Designing a fired heater like piece of equipment is not an easy stuff like a shell & tube heat exchanger. I wonder if standard design procedure exist with operating companies, there could be guidelines which can help you in certain aspects of fired heater design but complete design along with instrumentation and all is done by vendors.
Posted 31 March 2016 - 04:34 AM
I see that this query was asked some time ago, but for the record...
As Mr Padmakar Katre mentioned, the design of a fired heater is very complex and selection of the initial configuration requires understanding of factors such as flux and flow regimes of the process fluid.
The design is even more complex for vaporizing process streams.
Hysys or Pro II is not capable of simulating a full robust design, but instead there are specialist software tools for the purpose of designing heaters.
There is actually a new software available called Heater560, which is the most user friendly software for fired heaters and also produces datasheets, drawings and cost estimates ( more info: see http://www.heatersim.com ).
Typically, fired heater design is based on variations of the correlations developed by Lobo & Evans (in the 1940s/1950s). These correlations are quite complex to carry out by hand, as the procedure will involve a number of iterative calculations in order to converge at a reliable design solution.
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
