Dear all,
Thank you in advance for going through my query.
I have joined a company who are responsible for etablishing a Natural gas processing plant of 60MMSCFD using silica gel.
Though There is a consortium with a reknowned company but the process implementation has to be done by us. I am facing a dilemma regarding the accuracy and efficiency of the Desiccant tower switching issue.
Please do correct me and guide me if I am wrong; The main objective is to dehydrate the gas and then regenerate the tower again using heated gas. The process description is given below.
1. Our project is 3 tower based
2. One will be in adsorption while one will be in cooling and the last one will be in regeneration stage and that's how the cycle revolves.
3. In adsorbtion the gas enters from top of the tower but for regeneration (heating) and cooling the gas enters at the bottom.
4. All this switching will be done on the valve skid where 18 solenoid valves gonna be in action
If the switching was done instaneously there would have been no issues,but the problem is as per vendor of the silica gel the time for adsorbtion is the highest and for heating it is 84 seconds less and for cooling it is 168 seconds less than adsorbtion.
My question is if I wait for the adsorbtion to complete and run the heating and cooling process as it is won't it be harmful for the silica gel properties. Also each process has its own pressure setting; adsorbtion 78 bar, Heating 80 bar and cooling 76 bar.
I would really appreciate if someone kindly and considerably shares his/her experience regarding this issue. Whether to adjust the process such way that all the three process consumes almost the same amount of time or switch the valve in any other way which will allow and satisfy all the process requirement including the equalization of the pressure?
Apologies in advance if you find my query novice, which I am
. With all due respect I just don't want things to get done but to understand how they are done and why particularly that way. As I have just started my carrer as a process engineer I hope that my respected seniors and experienced members here will rectify me and guide me to become a better engineer.
Thank you & best regards,
Mohaimin Sunny
