Gas Stream Velocity For Two-Phase Flow Mach Number Calculation
psv;mach number;flow
#1 Steve90
Steve90
  • 71 posts
Posted 25 December 2015 - 03:51 AM
Hi guys ;
When calculating the two phase flow velocity for Mach number calculation; I'm using the total stream flow from hysys and i'm dividing it by the section .
Is this correct for two phase stream velocity or is there any method to calculate and determine the gas velocity for mach number calculation in 2 phase flow stream .
Thx
#2 Bobby Strain
Posted 25 December 2015 - 10:16 AM
Mach number is not a value used for two-phase flow. The term critical flow is the proper terminology. You won't find very much information on the subject.
#3 serra
serra
  • 311 posts
Posted 27 December 2015 - 02:58 AM
for two phase see the link in your previous thread on the subject,
"http://www.cheresour...rbons-mixture/"
for two phase there are models such as HEM, HNE, NHNE etc.
you may find many threads discussing this topic at cheresources forums,
see for example
"https://www.google.c...e cheresources"
