Hi I have have found a past paper question for an oil and gas module that I cant answer, does anyone know the source of corrosion on the attached photo? Corrosion has been highlighted in the pink areas, the process is at the front end of a refinery, any tips on controlling the corrosion would also be appreciated.
Capture.PNG 90.85KB
2 downloads
Identification Of Corrosion Source
Started by efg1259, Jan 07 2016 11:52 AM
corrosion oil and gas refining refinery
Posted 07 January 2016 - 11:52 AM
Posted 17 January 2016 - 08:27 PM
efg1259,
You can review the "API Recommended Practice 571: Damage Mechanisms Affecting Fixed Equipment in the Refining Industry", Chapter 5, p. 67., or "Petroleum Refinery Engineering" by Nelson, 4th. edition.
Napo.
Blocked Outlet For Continous SourceStarted by Guest_56200358_* , 03 Feb 2025 |
Corrosion In RefineriesStarted by Guest_CHEMSTRONG_* , 19 Jun 2022 |
Refinery Corrosion InhibitorsStarted by Guest_CHEMSTRONG_* , 03 Apr 2022 |
Corrosion Under Deposition At Trim Cooler Of Rfcc Main Fractionator OvStarted by Guest_Eric Nguyen_* , 19 Jul 2021 |
Does Ptfe Based Grease React With Anti-Corrosion Agents And Dissolve IStarted by Guest_Sam1999_* , 29 Apr 2021 |
