Hi all,
how to convert MMSCFD to m3/hr (gas)?
Is it possible to directly convert ft3/day to m3/hr for million quantity? i.e, 1MMSCFD=1179.868m3/hr? Is it correct?
Posted 10 January 2016 - 03:13 AM
Hi all,
Posted 10 January 2016 - 03:51 AM
blesson,
I would advise you to purchase Uconeer from our forum member (katmar) , by far the best in the class . This is for your entire life as Engineer . Google Uconeer and you will find the link .
For your specific question,
You should define your standard condition prior to convert (T,P)
Good Luck
Posted 10 January 2016 - 05:11 AM
Thanks Mr.Breizh for introducing the software.
Operating conditions of natural gas is 55 deg C,30 barg.
Posted 13 January 2016 - 07:29 AM
Blesson,
When you say MMSCFD of gas, intrinsically you define the standard conditions, they normally are 0ºC and 14.7 psia (in the petroleum industry they are 15.6ºC and 14.7 psia).
Then, 1000000 SCF/day x 1 m^3/(3.28)^3 cf x 1 day//24 h = 1180.78 Sm^3/h (Standard cubic meter per hour).
For another conditions (pressure, temperature) the conversion factor is the same.
Napo.
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
![]() Vacuum Getting Disturbed Periodically In Vacuum UnitStarted by Guest_aka28_* , 08 Oct 2024 |
