Design Of Fluidized Bed
Started by Radionise, May 31 2006 08:20 AM
Posted 31 May 2006 - 08:20 AM
Hi all,
I need to design a lab scale fluidized bed (i.e. around 1m tall and 20 mm in diameter, just a rough indication). It will be used to combust a biomass material.
I've operated both lab and pilot scale fluidized bed combustors before but I have no idea on the design itself.
As I'm aware, there are quite a few things that need to be considered here. For instance the design of distributor plate, and sizing of cyclone etc. Hopefully you'd be able to tell me briefly how I should proceed with the design.
Please advice. Thanks.
Posted 01 June 2006 - 06:14 PM
Please specify what is your particle size. In-order to minimize wall effects tube or reactor diameter should be atleast 8 times the particle diameter. Richardson-Zaki equation is widely used and popular for calcuating superficial velocity (in liquid-solid fluidization). There are various theories behind gas-solid fluidization starting with Ergun equation to the latest.
The distributor design may depend on fluid you use, particle size, etc. If there is biomass involved, and oxygen (aerobic reaction) is required, the flow rate is critical too.
If you can provide specifics on the system, experts in the forum would be able to help you.
-CTilara
-CTilara
Posted 10 January 2010 - 09:40 AM
Book on fluidization
" Fluidization Engineering, Second Edition By D. Kunii, Octave Levenspiel" would help you to understand and design Fluidized bed reactor.
Hi all,
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
