Co2 Removing Technology Selection From Natural Gas
Posted 18 January 2016 - 02:23 PM
Posted 18 January 2016 - 05:31 PM
You should look at BASF aMDEA. They require a license fee, but energy savings are substantial. And they will provide basic design information, too. Also Huntsman. But MDEA in some form is likely your best choice.
Posted 19 January 2016 - 12:26 AM
And the second question is the general process - Amine treatment is the best solution? What about membrane technology, what they required
Posted 20 January 2016 - 11:47 AM
MDEA could possibly remove the required amount of CO2 for your plant. You need to remove roughly 50% of the CO2. I have seen many MDEA units do that. It depends on your residence time for the chemical reaction. You will need a high residence time to achieve this with MDEA.
The other option I would suggest is DGA. It will have similar performance to aMDEA, as far as energy consumption is concerned. It will remove pretty much all your CO2.
An alternative to an amine process would be Selexol (DEPG) or Methanol. This option would likely have the least operating cost, especially in cold environments.
A membrane may be a good option, too. Frames would be a good company to explore that for you.
You can easily compare all these options in your ProMax model before going to a vendor so you can narrow down your choices.
Posted 20 January 2016 - 11:27 PM
You mean MDEA and aMDEA is the same or different? I suppose aMDEA is the mixture of MDEA 45% of weight and activator ti fast reactuon with CO2 - 5% of DEA for example. Am I correct?
What another actuators is used?
Could you please share name of companies where I can go for engineering and manufacturing of:
Amine units for CO2 remove
Membrane units for CO2 remove
Another technology for remove CO2
I have only Hysys and do not have Promax
Dmytri
Posted 21 January 2016 - 12:50 PM
I have used aMDEA from BASF (now INEOS), they work great for Co2 removal. the activator that i know of is piperazine.
Also read some literatures that Alstom have technology to use ammonia to remove Co2. Not sure whether it is commercial or just pilot stage.
Posted 21 January 2016 - 02:46 PM
Activators would be DEA and piperazine (most common). MDEA would be roughly 50/50 MDEA and water. aMDEA is typically 7% piperazine and 43% MDEA.
In the absence of having the proper engineering tools to do an evaluation yourself, you are right that you will need to go directly to an engineering company to do all the work. There would be no point in modeling this in Hysys.
BASF and Huntsman are options for amine processes only.
Dickson is a company I would try. Interstate Treaters is another. Of course, you also have the big companies to consider, such as WorleyParsons, Technip, and Foster Wheeler and others. Any of those should be able to evaluate your options for chemical and physical solvents. Frames would be a good option for membranes. Dickson would be the first call I'd make. They should be able to evaluate all your options.
Posted 22 January 2016 - 12:35 AM
We used MDEA with water on previous Gas plant. Is any changes with operating parameters for using aMDEA if compare MDEA. I mean for example regeneration temperature and pressure in stripper
Posted 22 January 2016 - 12:40 AM
RockDock:
Thanks for the names of Companies. I will contact to them soon.
Before we worked with Huntsman, they supplied MDEA for our Amine plant.They are very good.
Do you can compare Amine and Membrane. methods for CO2 remove?
Only design company can select which method is better? Or client (my company) can select based on some limits?
#10
Posted 22 January 2016 - 09:45 AM
I dont see any change in operating parameter between MDEA and aMDEA
#11
Posted 22 January 2016 - 10:25 AM
No problem.
You could certainly do some evaluation on your own comparing chemical solvents, physical solvents, and membranes if you had the right tools. You would likely be able to narrow it down to one process before sending the detailed engineering to an external engineering company. That is not an evaluation anyone would recommend using Hysys. I think your best option would be to send it to en engineering company to complete all the options.
You may see some slight differences in reboiler duty between aMDEA and MDEA. Piperazine requires more heat to regenerate which is why you only have a small amount of it. The temperature of the stripper is dependent on the pressure not the duty. The temperature will be the boiling point of water at the given pressure.
I've also had great experiences with Huntsman.
#12
Posted 22 January 2016 - 11:47 PM
RockDock:
On my Amine plant with MDEA 45-48% by weight pressure in Stripper was 1.6 barg in bottom and 1.3 barg in top. Acid gas goes to SRU with pressure 1,1 barg.
Temperature in bottom was 120-125 deg.C.
On the top we set it at 110 deg.C.
AMDEA + piperizane will have the same parameters?
#13
Posted 26 January 2016 - 09:54 AM
aMDEA would be the same for the above process details. However, the reboiler duty would likely be different, as freeing CO2 from MDEA requires less heat of reaction than from piperazine. That means you will likely need more steam generation in order to hit your 110 C set point.
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
![]() Activated Carbon SelectionStarted by Guest_Talhafarooq_* , 25 Nov 2024 |
Separation Technology For Separate / Distillate Hcl From Water MixtureStarted by Guest_dpunnn_* , 11 Sep 2024 |
Looking For Technology And Software Related WebsiteStarted by Guest_Ashish__* , 03 Sep 2024 |
