Dear,
I'm projecting a vertical drum vase that will separate water and oil from gas, but I have to know what residence time (Tr) to use, because I work in a mature field company, so the liquid part is 98% is water and 2% is oil. I found that for less API grade we need less residente time (Tr), I can apply this to this mixture of oil and water? Please help me to solve this probleme. If you have any material that may contain this information send me. Thanks for reading this.
Best regards,
Daniel
Api Grade Of Oil
Started by fazzioni, Feb 04 2016 09:53 AM
api oil api grade drum vese vertical drum vase mixture residence time mature fields
Posted 04 February 2016 - 09:53 AM
Posted 05 February 2016 - 02:24 AM
Daniel,
Since the oil content is very low in water. I would suggest you to go with Coaleser Plate Pack as an internal.
Food Grade HexaneStarted by Guest_shahabn_* , 26 Nov 2023 |
High Grade Composite FibreStarted by Guest_Mukarram Hassan_* , 10 Sep 2016 |
Food Grade Phosphoric AcidStarted by Guest_bhdrsc_* , 11 Feb 2016 |
Help: Biodiesel From Cpo Off-Grade (High Ffa) Process SimulationStarted by Guest_karna bratha_* , 04 Jun 2014 |
Bitumen Pure Grade 40/50Started by Guest_DANA-IF_* , 11 Sep 2014 |
