Dear,
I need to know the force of a passage heater for a petrochemical industry, because when the environment get cold the line has paraffin problem. We need that the mixture of oil and water be at the end of the line with 50 °C, the line has 1000 meter distance from the point of the passage heater to the end of the line, the flow has 15 m³/d and the fluid will enter in the passage heater at 40°C. I need any kind of help. Thanks for readind this.
Best regards,
Daniel
Passage Heater Project
Posted 10 February 2016 - 05:32 AM
Posted 10 February 2016 - 11:52 AM
Daniel:
Without any further details and basic data, it seems like this is a typical transport line jacketing or heat tracing application. I have to do a lot presumptions (guessing) because of the lack of additional data, but if it were up to me and the situation could not tolerate a shutdown with an installation of steam jacketing on the transport line, then I would apply either steam tracing (as per the attached documentation) or electrical tracing followed by complete, adequate insulation on the kilometer of distance.
This is an expensive solution, any which way you decide to go, but before doing any of the options you should do a very detailed calculation for the required heat input on the transported fluid and an accurate calculation for the properly applied insulation AND vapor barrier on the pipeline. If you opt for the tracing solution, you can probably do it while the pipeline is in place and while it is in operation. You may not have to actually trace the complete kilometer length of pipeline, but you have to calculate the heat input required and the efficiency of your applied insulation.
The above may not be the correct answers or what you like, but our members and your response may give rise to more accurate and factual information and data that would lead to a reasonable and accepted solution.
Thermon Steam Tracing Manual.pdf 159.19KB
1039 downloads
Steam Tracing with MS Excel.docx 543.72KB
1745 downloads
Steam Tracing(2).xlsm 403.11KB
2955 downloads
Posted 11 February 2016 - 08:07 AM
Art Montemayor,
Thanks a lot for the feedback, but the local that we are working can not support heat tracing occupation because is too far of the main station. So the passage heater that we are evaluating is a resistence and have to heat much high than 50 °C for lose along the line and be at the end of the line at 50 °C. We can considerate 90% oil and 10% water. The passage heater is equal to this one in the
link below:
http://www.higher.co...ge heaters.html
Thanks for the spreadsheet and the manual you gave to us, I'm sure this will be helpful one day to me and will be helpful to the others members.
Best regards,
Daniel
Idea For ProjectStarted by Guest_Prab_* , 13 May 2025 |
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
![]() Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Design Of A Psa Unit For Undergraduate Design ProjectStarted by Guest_LMorgan14_* , 04 May 2021 |
