Statistical Thermodynamics
Posted 15 February 2016 - 05:29 AM
It is stated that for a system to be in equilibrium ds = 0. Is this true for all systems, including phase changes? Because when deriving the Claudius clapeyron equation, it is stated that for a single component in phase equilibrium the following must be satisfied,
The chemical potentials must be equal between the liquid and gas phase and dG = 0. This I understand because both component must have the same Gibbs free energy during a phase change, but what about ds=0 for phase changes? Is a phase change not an equilibrium state?
Posted 15 February 2016 - 06:15 AM
Dear Karen123
Check this link for example:
http://web.gps.calte.../tutorial1.html
I'm not an expert, but I remember from my thermodynamic class back at university, that you can derive different equilibrium criteria, depending of which variables are kept constant in the system: P, T, E,V etc, which translate to different quantities being minimized or maximized: S, H, G, A (Helmholtz free energy). In particular G is minimized in a spontaneous process at constant pressure and temperature, a restriction that we tend to forgot fast xd.
Best regards.
Posted 15 February 2016 - 07:04 AM
two phases in equilibrium does not entail that there is no phase change, but phase change always does not mean that the phases are at equilibrium... please think over it...
Posted 16 February 2016 - 10:42 AM
I feel like there must be some context missing from this. It is pretty clear that, in a two phase system, the entropy of the vapor and the entropy of the liquid will be different. This is easy to see using a calculator like NIST's (http://webbook.nist....hemistry/fluid/ pick any fluid and compute equilibrium state). You should see that entropy of the vapor phase and entropy in the liquid phase are different. Either the statement is specifically talking about equilibrium in a single phase system, or there is something else being discussed that gives that condition.
Thermodynamics Basics CalculationStarted by Guest_Em_And_Chem_* , 11 Sep 2023 |
ThermodynamicsStarted by Guest_thamar_* , 30 Aug 2021 |
Thermodynamics In IndustryStarted by Guest_Qasem215_* , 04 Jun 2020 |
![]() Thermodynamics QuestionStarted by Guest_Blank03_* , 15 Jun 2018 |
![]() Thermodynamics QuestionStarted by Guest_SR23_* , 18 May 2017 |
