So I'm designing an absorption column.
I have the flow rates/ temperatures of the inlet streams for the solvent and solute. I also have the compositions of the stream. Densities, viscosities are also known.
How would I go about calculating the height of a packed bed and tower tray absorption column as everything I come across seems to want to calculate un relevant variables.
Yours truly,
Muhzayn
Posted 16 February 2016 - 01:04 PM
Posted 17 February 2016 - 06:04 AM
Dear Muhzayn:
You can check chapter 6 ("Absorption and stripping of dilute mixtures") in the book "Separation process principles", by Seader, Henley and Roper.
Assuming your process doesn't involve chemical reactions, it must work for you. The book goes step by step in the design procedure, and the aspects that must be considered.
Best regards.
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
Aspen V11 Help On Radfrac Distillation Column ErrorStarted by Guest_savinedanglokta_* , 13 Nov 2024 |
Pressure Drop Due To Entry Loss At Liquid And Gases Inside The ColumnStarted by Guest_SANDEEPCH_* , 24 Oct 2024 |
![]() Batch Distillation Column DesignStarted by Guest_Mubie_Bear_* , 18 Sep 2024 |
