Vba Code To Extract Volume, Fugacity, Enthalpy And Entropy Derivatives
vba code volume entahlpy entropy derivatives prode
#1 mattb
mattb
  • 10 posts
Posted 22 February 2016 - 09:02 AM
can you refresh my memory as to how to extract composition and temperature derivatives of fugacity, volume, enthalpy and entropy with VBA code from Prode Properties ?
I have the C code working but I need to convert to VBA and I have problems with pointers,
I think there was a VBA code here posted by Paolo but I am unable to find the post at cheresources forum...
Thanks for help.
#2 PaoloPemi
PaoloPemi
  • 550 posts
Posted 22 February 2016 - 11:04 AM
as for C / C++  etc. with Prode Properties you can access directly the functions to calculate
Fugacity + derivatives (vs. p,t,w)
Enthalpy + derivatives (vs. p,t,w)
Entropy + derivatives (vs. p,t,w)
Volume + derivatives (vs. p,t,w)
with VBA you need to create a space (remember first element is 0 as in C)
for example you may write something like this
' define space
Dim w(0 To 10) As Double
Dim dVw(0 To 10) As Double
' initialize process
process = 1
res = DPinit(process,stream)
' define composition
w(0) = 0.81
w(1) = 0.09
w(2) = 0.06
w(3) = 0.02
w(4) = 0.01
w(5) = 0.004
w(6) = 0.006
w(7) = 0.0
w(8) = 0.0
w(9) = 0.0
t = 280
p = 250000
' calculate volume and dV/dt dV/dp dV/dw
res = StrVvd(process,1,t,p,w(0),V,dVt,dVp,dVw(0))
in a similar way you can calculate the fugacity, enthalpy and entropy.
Being a direct access execution is fast,
for complex models such as CPA or SAFT you may allow some additional time for solving the association contribute,
Paolo
#3 mattb
mattb
  • 10 posts
Posted 30 March 2016 - 02:24 PM
thanks Paolo,
I was able to extract the values following your instruction,
do you know if these are numerical or analytical ... ?
Edited by mattb, 30 March 2016 - 02:24 PM.
