Jacketed Heat Exchanger
Posted 09 March 2016 - 08:02 AM
Posted 09 March 2016 - 10:04 AM
Shamsey:
Our members can't "guide" you through what you have done and what you should do if you don't furnish your work and calculations.
They don't know what you have done or are doing without seeing your work and checking it - as is done in all world-wide engineering projects and calculations. That is standard engineering practice.
If you attach your calculations and procedures in a typical engineering electronic spreadsheet you can allow our members to check your method and calculations, as well as add their suggestions and recommendations. This is all to your advantage and profit. If you furnish your spreadsheets, don't lock them with a password; this makes it difficult for our members to check, review, and correct any mistakes or omissions.
Posted 10 March 2016 - 03:52 AM
Art Montemayor:
Thank you for your response and the guidelines. I am attaching my working sheets for the ease of members.
For clarification, I am in the preliminary phase of calculations. I need guidelines regarding how to size jacketed heat exchanger and what are the criteria for baffle size selection. Plus the pressure drop the jacket imparts.
Thank you and Best Regards.
Posted 08 July 2016 - 08:48 PM
Thank you!
Posted 14 October 2016 - 12:24 AM
Hey I am Daneil Smith and I have recently joined this site.Its a nice place to get a lot of info and I have a page to share about 44-inch heat transfer calendar.
Posted 14 October 2016 - 08:35 AM
Shamsey,
Here are several literature sources on jacket vessels with agitation:
Process Heat Transfer by Kern
Process Heat Transfer by Hewitt, Shires and Bott.
This has a chapter on Heat Transfer in Agitated Vessels
Lng ExchangerStarted by Guest_guoyinyanliner_* , 10 Feb 2026 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
