Dear members, I would like to ask you about opinion about the easiest way to recreate equipment at lab scale for coating of iron nanoparticles with the polymer, I am thinking either to use supercritical CO2 chamber or to make some microfluidic system, but I am not sure which one would be easier and safer to make? I am not engineer and I am concerned with possible consequences that can arise from wrong design. any suggestion is welcomed
Continuous-flow Photochemistry In Microreactors Vs Supercritical Fluids
Started by SSimone, Mar 13 2016 04:27 AM
equipment scf handmade microfluidic safety difficulty
No replies to this topic
Posted 13 March 2016 - 04:27 AM
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
Pump-Continuous Flow After TripStarted by Guest_stu_* , 28 Jan 2024 |
Inquiry On Calculating Residence Time Of Fluids In SeperatorStarted by Guest_MJA99_* , 07 Oct 2023 |
