Hi guys ;
Anyone have an idea how to calculate the oil content in water in the outlet of a three phase separator with weir arrangement ?
Posted 23 March 2016 - 05:12 AM
Hi guys ;
Posted 29 March 2016 - 06:18 AM
The constant K (entrainment factor) is defined while sizing three phase separator. This k factor defines to keep minimum entrainment for given pressure conditions. Another deciding factor is particle size. Both these inputs, make design adequate to achieve maximum separation. However, there is no direct calculation method (I know) to estimate oil in water, as well as water content in oil . I guess, it is experimental data & only fabricators can indicate.
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , Yesterday, 11:51 PM |
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
