Heat Exchanger Material Selection
#1 Jackwill
Jackwill
  • 17 posts
Posted 24 March 2016 - 05:56 PM
I am using dowtherm within the tubes of a shell and tube heat exchanger. The other fluid which passes outside the tubes is saturated steam which condenses upon contact with the tubes. Would 0.5% carbon steel be suitable for this? Or would it be susceptible to erosion and/or corrosion?
P.S is stainless steel a better option?
Kind regards
J. Will
  • 6,929 posts
Posted 24 March 2016 - 06:16 PM
http://msdssearch.do...fromPage=GetDoc
You may find what you are looking for using this link..
Edited by breizh, 24 March 2016 - 06:49 PM.
#3 srfish
srfish
  • 408 posts
Posted 25 March 2016 - 11:47 AM
According to a Platecoil booklet, Carbon Steel is not fully resistant.
#4 PingPong
PingPong
  • 1,474 posts
Posted 25 March 2016 - 12:37 PM
Depends on the temperature.
#5 shantanuk100
shantanuk100
  • 104 posts
Posted 28 March 2016 - 02:58 AM
Hi Jackwill,
You should check the material compatibility charts available for these conditions.
There are numerous sources for the fluid compatibility with different materials.
Shantanu
Edited by shantanuk100, 28 March 2016 - 04:15 AM.
#6 Padmakar Katre
Padmakar Katre
  • 992 posts
Posted 13 April 2016 - 12:10 AM
Kind regards
J. Will
I don't see any issue with using CS material for entire exchanger, dowtherm is fouling but not corrosive hence should be ok.
