I have a process to recover H2SO4 from spent acid dillute stream in any
industry, which is finally converted to Ammonium Sulphate efficiently
without much operating cost.
This Ammonium sulphate is anhydrous.
Now I am looking for either converting it back to conc. H2SO4 & recycle ammonia.
OR use it for further value addition.
Any suggestion is welcome
____________________________________
Visit my Blog - http://profmaster.blogspot.com
Ammonium Sulphate
Started by pawan, Jun 06 2006 04:48 AM
Posted 06 June 2006 - 04:48 AM
Posted 10 June 2006 - 09:14 AM
Hi, Pawan
It does not seem economical to recover sufuric acid and ammonia from anhydrous (NH4)2SO4 even if it is possible. Ammonium sulfate could be used as a fertilizer for plants but it tends to acidify the soils.
You'd better, instead, recover concentrated sulfuric acid from the spent acid recovery system. Probably, low-concentration sulfuric acid could be distilled in a glass-lined stills to get higher concentration acids.
sgkim
sgkim
Hysys Convergence Issue Related To Ammonium SulfateStarted by Guest_Victfmanzana_* , 27 Jun 2024 |
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
![]() Ammonium Nitrate Simulation In Aspen-Missing ParametersStarted by Guest_aa2526_* , 18 Feb 2021 |
Ammonium Bicarbonate ProcessesStarted by Guest_bhdrsc_* , 30 Nov 2020 |
![]() Ammonium Hydroxide Latent Heat Of VaporizationStarted by Guest_Chris Lee_* , 03 May 2018 |
