Packed Column Redistribution Ring
packed column redistribution
#1 Pingue2008
Pingue2008
  • 136 posts
Posted 28 March 2016 - 09:50 AM
All,
I have a packed column that separates water from ethylene glycol (EG). I have noticed a drastic reduction of the column efficiency due to channeling more on one site. last week we had a scheduled shutdown,  i realized looking into the tower that a quick fix could be to install re-distribution rings throughout the tower to collect fluid from the wall and try to put it back in the center. Since i am not an expert, i wanted to know the criteria.For example: how many rings per column height? how many pipes/tubes per diameter etc...
If you have done such work and have some references please share with me. attached is a sketch of my design
Thank you,
#2 shantanuk100
shantanuk100
  • 104 posts
Posted 29 March 2016 - 03:03 AM
Hi Pingue,
Could you mention the height of your packed column ?
If your bed is longer than 10 ft, you require a second bed with an additional redistributor in between, in order to avoid fluid channeling and collection.
Redistribution rings can be used, but check out redistribution criteria given in Kister's distillation design, or get supplier info on empirical data.
They are pretty useful.
Shantanu
Edited by shantanuk100, 29 March 2016 - 10:57 PM.
#3 breizh
  • 6,789 posts
Posted 29 March 2016 - 06:22 AM
Pingue 2008,
Take a look athe literature attached.  all these equipment are sophisticated !
Sulzer /Norton websites should also support your work .
Hope this helps
#4 Pingue2008
Pingue2008
  • 136 posts
Posted 04 April 2016 - 02:14 PM
Thank you guys.
I did a high pressure wash of the distribution plate. the holes on the tubes got cleared and I also increase the overall height of the distribution outer shell.
I called the manufacturer and they were asking for too much information (simulations etc...) i did not have time for all that this shutdown. my shutdown was going to last only 15 days. Since start-up couple of days ago the column is performing extremely well (I hope it stays that way :) ).
Thank you for your inputs.
#5 breizh
  • 6,789 posts
Posted 04 April 2016 - 07:02 PM
Hi Pingue 2008 ,
Turn around or shut down periods are "golden mines" to resolve problem on harware . With a good PM program in place  you should be able to fix similar issues.
Good luck .
#6 navdeeptrident
navdeeptrident
  • 3 posts
Posted 06 April 2016 - 12:31 AM
can anybody help me to design a plant for acrylonitrile production 90000 tons/year by propene ammoxidation using osw process
#7 breizh
  • 6,789 posts
Posted 06 April 2016 - 03:16 AM
navdeeptrident:
Don't jump on an existing thread!  Consider to start a new one. To be frank with you, we can support you as long you are able to show us your effort to resolve your problem.  We will not do your homework .
good luck.
