hi all,
Can some one tell me that when I mix two miscible liquids in weight ratios what is the equivalent density and viscosity???
Density And Viscosity Of A Mixture
Started by , Jun 09 2006 02:55 AM
Posted 09 June 2006 - 02:55 AM
Posted 13 June 2006 - 06:13 AM
You may try
Ln(viscosity) = SUM ( xi * Ln(visci) ) xi mole fraction of component i ; visci viscosity of pure component i
Ln designates the Natural logarith (base e)
do not use for mixtures like water -glycerol
You may also try Kendall & Monroe's rule viscossity = (SUM x1 * visci^0.333 )^3
Posted 17 June 2006 - 03:54 PM
QUOTE (gatty12 @ Jun 9 2006, 09:55 AM) <{POST_SNAPBACK}>
As for the density - there is no general, bulletproof method, as the volumes of the solutions are not additive. For example if you mix 50 mL of water and 50 mL of ethanol you will get no 100 mL of solution, but only 96.42 mL.
In general, to be able to correctly calculate density of mixture you need to use density tables. I suppose the same holds for viscosity, although that's only my (educated) guess.
Understanding Polytropic Head And Its Relationship With Gas DensityStarted by Guest_Kakka_* , 18 Dec 2024 |
Negative Sign In Newton's Law Of Viscosity?Started by Guest_Cheeky_* , 24 Oct 2024 |
Separation Technology For Separate / Distillate Hcl From Water MixtureStarted by Guest_dpunnn_* , 11 Sep 2024 |
![]() Prv Fire Case Load Calculation For Mixture.Started by Guest_Halflight_* , 24 Jun 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
