Performance Curve For Blower
#1 Pinggy
Pinggy
Posted 28 April 2016 - 11:34 PM
I need to design blower at suction temperature air at 30 oC, DP = 1020 mmAq, Q = 24480 Nm3/h.
Vendor submit performance curve for fan as attached.
Due to temperature at my country can reach 42 oC. I need to change suction temperature from 30 oC to 42 oC and DP = 980 mmAq, Q reduce.
Vendor inform me:
Normally, if suction temp. is changed, performance curve is changed too.
Please help me confirm that if suction temp. of blower is changed, performance curve is changed too or not.
Thank you,
Pinggy
  • 6,962 posts
Posted 28 April 2016 - 11:56 PM
Hi Pinggy ,
Consider this paper to support your work . Pressure is affected by the change in temperature.
http://www.gasho.org...tion-Basics.pdf
#3 fallah
  • 5,026 posts
Posted 29 April 2016 - 12:07 AM
Pinggy,
Yes, if the suction temperature is changed performance curve of the blower changed too...
#4 Tdha
Tdha
  • 4 posts
Posted 02 May 2016 - 11:21 AM
Performance curves are made for a given density, impeller diameter, speed, and so on... Temperature and suction pressure affects the density of the blowed medium, thus different performance curves are needed.
#5 Julien123456789
Julien123456789
  • 94 posts
Posted 03 May 2016 - 07:25 AM
Pinggy,
H-Q is the only thing that is independent on temperature.
Changing inlet temperature, fluid density will be consequently varied, the performance curve P-Q will move.
Julien
Edited by Julien123456789, 03 May 2016 - 07:33 AM.
